ROP in compile
   1486   3   0
Hi everyone,
I do a cop process in sop context, inside a subnet inside a for-each loop
I already know how to auto-ROP an image using python at each loop.
Is there a way to auto-ROP if I put my loop in a compile node ? (python node isn't compile-compatible)
Cheers
absolutely not!
Consider unrolling your loop so that each 'frame' is a different loop iteration, and use a shell rop to set the iteration value and execute the rop for that loop iteration.
You can also use TOPs to process multiple iterations in parallel instead of compiled foreach
Edited by tamte - Aug. 5, 2022 13:43:29
FX Supervisor
Method Studios, NY
ok thanks. I already know about PDG but the overhead is too much for my purpose.
I'll dig into this shell thingy; never used that before.
cheers !
