Houdini viewports are slow in any mode with wireframes
   559   2   1
I have around 4000000 polygons in a scene, and the viewport gets extremely slow (3 fps) for any mode with wireframes enabled.
I'm on M1 macOS version 12.5, Houdini 19.5.337.
Has anyone encountered the same problem and what could be a possible solution?
You might want to post this on the Apple Silicon forum.
Did a quick test on my M1 MBA (8GB with 7 core GPU). For me wireframe made no difference; was getting around 4fps. Given the power (or lack thereof) of the GPU this is kind of in the expected range to me. (Apple Silicon flavour of Houdini 19.5.369).
Which M1 are you using? Are you using the Apple silicon build? On my M1 Pro laptop I consistently get 20 fps in the viewport with a mesh containing 4398000 primitives. How many objects do you have in the scene?
