If I use the checkpoints the whole simulation just disappears. No matter what I do I just cannot see anything. Anyone else has better luck.
Another bug?
Flip Splash leaves little drops almost static in the air
4172 23 1- AndreasOberg
- 117 posts
- mrCatfish
- 731 posts
AndreasOberg
Here are the benchmarks
Global Substeps 1 Min:1 Max: 1 3min 15sec
Global Substeps 1 Min:1 Max: 3 8min 33sec surprised that this is shorter
Global Substeps 1 Min:1 Max: 2 18min 31sec
Global Substeps 2 Min:1 Max: 2 34min 40sec
To me it seems like global really increases time. After that it seems mostly that the size of the shape depends the time. The max 3 is fast, but its because it creates a quite small splash.
Upping global substeps (AFAIK) is really only necessary if you have fast-moving colliders. This is because the collision object is only sampled according to global substeps. However, if you have no fast colliders, it's more efficient to simply increase min/max substeps.
- Min/max of 1/3 with global of 1 = min/max of 1/3
- Min/max of 1/3 with global of 2 = min/max of 2/6
Sean Lewkiw
Machine FX - Cinesite MTL
- Benyee
- 56 posts
- AndreasOberg
- 117 posts
BenyeeOk, have not really tried that will check. Thanks!AndreasObergtry obj/geo1/fliptank1:Grid Scale with 1.5?hope it helps
looks a bit like a drop on a window slowly falling down. Any idea what is going on?
I find that with min 1 and max 3 I do not get the stuck drops. To me its very odd though, how on earth can they detect a collision in mid air when there is nothing there even at min 1 and max 1 steps.
