hi,
i have an asset geo as an HDA...
when modifying i typically create a new version and it will be saved with the new version number, which is fine, so i see a bunch of hda files in the hda folder...
but when an older version of the hda was placed in a hip, how can it be replaced with the new version? in maya i would "replace reference" in the reference editor.
what is the equivalent to this in houdini? and how can this be automated?
HDA Asset Workflow
1219 4 2- soulcage_dpt
- 45 posts
- Andr
- 900 posts
- soulcage_dpt
- 45 posts
thx for the hint...i will try.
normally it shouldnt update automatically, because lets say you are middle in rendering with v1.1 and modify to a new v1.2...then when it automaticalky updates then you mess up rendering...
(but there are situations where you want to automate the update process)
Edited by soulcage_dpt - Sept. 24, 2022 06:12:57
- Andr
- 900 posts
- Jikian
- 131 posts
You can create a button in the Toolbar that compiles which nodes are using outdated definitions:
e.g. a node named "namespace::myHDA::1"
...then filter node.path()'s result to convert the nodes you want.
import hou customNodes = [x for x in hou.node("/").allSubChildren() if x.type().nameComponents()[1] == "namespace"] for node in customNodes: definition = node.type().definition() if definition.nodeType().name() != hou.nodeType(definition.nodeTypeCategory(), definition.nodeTypeName()).namespaceOrder()[0]: print("Warning... Node instance is using older definition: ", node.path())
