So in Hou 19 the Mountain node was replaced by the Attribute Noise node. OK no problem, but where is the "time" slider in the attribute noise? How can I get something similar?
Thanks in advance
GS
Mountain to Attribute Noise: time slider?
1603 5 1- Grendizer
- 375 posts
- jsmack
- 7733 posts
- Grendizer
- 375 posts
Ok I was not sure it was the equivalent slider as a "pulse length" slider was already featured in the old Mountain node.
I'm not very satisfied with this node replacement. When I open an old Houdini scene and try to reproduce the mountain node in a new Attribute Noise node, it's not the same settings. In Mountain, my Height slider is set at 2.5. If I put the same value in Attribute noise's "amplitude", the input sphere is not deformed in the same way. So is there a "Mountain to Attribute noise" guide?
Houdini gamboler
- tamte
- 8513 posts
- jsmack
- 7733 posts
- Grendizer
- 375 posts
Well Ok I understand. But I still think Sidefx should have added a "mountain to attribute noise" guide in the Attribute Noise documentation. They could have explained, for example: in mountain if you put a height of 10, the equivalent is an amplitude of 1.
Mountain is very often used by Houdini users so I think this would have been useful.
Houdini gamboler
