i want to model gameassets in Houdini. And i practice to model some walls and pillars with destruction of age on it. So i converted the pillar in a vdb and made some holes and destructions with noises on that. Now i wanted to make the noise work only on the edges. I know the mask feature with the fog vdb, but this is not very intuitive. Is there a possibility to mask the edged like the measure-node with curvature?
masking edge in volume vop
1549 2 0- mutac0815
- 20 posts
- animatrix_
- 4509 posts
You can use VDB Analysis SOP, which has curvature and other operators:
https://www.sidefx.com/docs/houdini/nodes/sop/vdbanalysis.html [www.sidefx.com]
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
- mutac0815
- 20 posts
