Unfold or unroll SOP geometry using UV
1971 3 0-
- Dave_ah
- 436 posts
- tamte
- 9372 posts
- Dave_ah
- 436 posts
- Dave_ah
- 436 posts
How would that work in reverse , if additional geometry is added? Lets say an unrolled surface is scatterSOP with points then Copy To Points SOP is used to populate the surface. Then previously unrolled surface is rolled back to original shape. What I find is happening when Attribute Swap SOP is inversed is that added points are collapsed into same P as on original surface.
