SBD Pin Constraint broken?
   3104   2   2
Is the SBD pin contraint broken in 9.0.757? I can't seem to set a point to pin the cloth to, nor do I see the guide sphere.
See attached hip, or try it yourself.
  1. create default cloth object
  2. connect to cloth pin constraint
  3. connect to a gravity
  4. connect to a cloth solver
    run it and it just falls.
    fiddle with the constrain to animation switch on the constraint DOP or the Guide Options… still I get nothing.
brokenPinConstraint.hip (69.2 KB)
“If you can eat it raw you can't under cook it”
I'm not having any problem with the Pin Constraint.
In your file;
- Make sure you have the Constrained Object set to clothobject1
- Constrained Points set to a point number, ie. 70
- Toggle on Constrain To Animation
All the best,
Jenny.
Side Effects Technical Support
Ahhh, okay. My bad. DUH! Yes, must specify a point to constrain.
