I've been using 3dsmax and maya for 5 years now, and both of those programs have some default settings that you can change. How can I keep my project workflow in houdini?
1. How can I setup a project folder? Or just change a default folder to save files out? This $HIP seams to remember the last saved path file, but then I need to change every path to each file manually
2. I often noticed that flipbook stops rendering in the middle. So I learned that I need to change my ram settings in Cache Manager. But then whenever I reopen houdini I need to set those again. How to save those as default?
Houdini default settings
6087 2 0- JJ_FX
- 30 posts
- edward
- 7714 posts
Juzwa
If you load a .hip file, $HIP automatically changes to the parent subdirectory of that .hip file.
From Edit > Main Preferences.
- goldfarb
- 3455 posts
you can read through both of these…
they are a little old but the info is still very much applicable.
http://forums.odforce.net/topic/11737-configuring-hip-and-a-project-directory/ [forums.odforce.net]
http://forums.odforce.net/topic/659-houdini-project-directory-setup/ [forums.odforce.net]
