Example this…
a sphere as Flip Fluid from Object (with a Y position of 2)
a grid as a Static Object below with volume collision turned off.
the DopNet's flip fluid object is set to
particle separation 0.025 and radius scale 0.5
Frame 1 over 250,000 points
Frame 20 about half way collided has evaporated to under 60,000 points
Frame 40 below 5,000 points
So 98.8% of the fluid points have somehow evaporated upon collision with a simple grid <fact>.
My simple questions are…
How did that happen?
and
How can I stop flip fluids from evaporating seemingly illogically?
Flip Fluid evaporation? how to stop it?
6496 4 2- GottaGetmedat
- 68 posts
- PradeepBarua
- 443 posts
- GottaGetmedat
- 68 posts
Thank you for an attempt to help understand this.
It's so simple I didn't think you would need one. (I would have added changes needed from the defaults to describe steps to reproduce otherwise.)
I stripped it down to the bare essence once I realized it is in complete violation of the very physics it's suppose to be simulating.
Any change of a Flip Fluid Objects Geometry's point count by even 1 point is in complete violation.
Boundaries makes no difference. The default is off.
Your other thought is unclear I've described it as a FLIP Fluid from Object?! In the AutoDopNetwork generated it has a FlipSolver and a FlipFluidObject with default settings other then as described (only to enhance the effect with more production like settings).
For clarity it's a middle click on the FlipFluidObject to inspect the oddly shrinking Geometry's Point count.
PradeepBarua
Hard to guess without .hip
Do you have Closed Boundaries of Flip Object turned on.
- anon_user_37409885
- 4189 posts
- GottaGetmedat
- 68 posts
Yes okay thanks!
AutoDopNetwork FlipSolver1 <TAB>ParticleMotion <SubTAB> Reseeding Particles DISABLED
/obj/AutoDopNetwork/flipsolver1/reseed
Seems that is what made almost all the particles disappear on collision.
Now a particle is a particle and not part of some default Quantum delusion.
MartybNz
Hunt down Reseeding and turn it off - search for it in the manual.
