Hi there!
I have a file with a pyro simulation very heavy in voxels count. It's so slow in my machine. As far as I've been reading, I think its possible to distribute pyro simulations in different machines with Hqueue.
So here are my two questions:
1. Is this also possible to distribute my simulation with Amazon's EC2 Cloud? (Slice method I guess?)
2. Since my voxel count is so heavy that can crash my machine, is it possible to simulate each slice separately in my machine?
Thanks in advance!
Distributing simulations
4777 14 3- acacia
- 3 posts
- acacia
- 3 posts
- pbowmar
- 7024 posts
- pbowmar
- 7024 posts
- goldleaf
- 4159 posts
- pbowmar
- 7024 posts
- goldleaf
- 4159 posts
- pbowmar
- 7024 posts
- rvinluan
- 1255 posts
- pbowmar
- 7024 posts
Hi Rob,
Using latest 265 build, installed (update mode) Hqueue 265 as well, still get:
The Houdini 14.0.265 environment has been initialized.
PROGRESS: 0/24
File “/opt/software/hfs14.0/houdini/scripts/hqueue/hq_make_ifds.py”, line 4, in <module>
hqlib.callFunctionWithHQParms(hqlib.makeIFDs)
File “/mnt/opt2_900gb/opt/software/hfs14.0.265/houdini/scripts/hqueue/hqlib.py”, line 1848, in callFunctionWithHQParms
return function(**kwargs)
File “/mnt/opt2_900gb/opt/software/hfs14.0.265/houdini/scripts/hqueue/hqlib.py”, line 120, in makeIFDs
_invokeRopAndCatchErrors(rop, project_name, frame, False)
File “/mnt/opt2_900gb/opt/software/hfs14.0.265/houdini/scripts/hqueue/hqlib.py”, line 441, in _invokeRopAndCatchErrors
raise e
hou.OperationFailed: The attempted operation failed.
Error: Indie does not support generating disk files.
PROGRESS: 0/24
raise e
- pbowmar
- 7024 posts
- rvinluan
- 1255 posts
- pbowmar
- 7024 posts
Unfortunately, that's not really pratical The memory footprint of Hbatch + Mantra together can be prohibitive, requiring you spending more $$ on a larger Amazon machine. Plus it's much slower than dumping out your IFDs from one process then using Mantra to render them, since you then have to run Hbatch for every frame.
Anyway, I guess an issue for higher-ups. I will cease attempting to use Amazon Web Services. I never did get it to work anyway, but that's likely a separate issue.
- goldleaf
- 4159 posts
It's unfortunate these license limitations are so crippling when it comes to HQ; I thought it was just supposed to “work” based on your license type.
I feel the solution is either support lc/nc ifds; or mimic Pixar and make Houdini limitations license-only, and avoid altogether tiptoeing which license supports feature X, and to which degree. Honestly, I think the latter would be best in the long run, since anyone who'd break those agreements is probably just going to pirate the software anyway. Not having software limitations (maybe just keep existing watermarks on renders and in the scene view?) frees up developer resources/time, good PR, opens up for more folks to evaluate and learn all aspects of Houdini, etc…
Submitting an RFE now…
I'm o.d.d.
- pbowmar
- 7024 posts
