Is there any way to use scalar value for pcopen?
Such as pcopen(@OpInput1,“scalarAttr”,scalarVal,1,10); I tested ,but not worked.
pcopen with scalar attribute
1904 3 0- jerry7
- 620 posts
- animatrix_
- 4495 posts
Why do you want to pcopen a scalar attribute? Since point clouds are position based, you need vector values. You can read scalar attributes on these points using pcfilter though.
- jerry7
- 620 posts
pusat
I think if can I do something with same scalar attribute. Such as get average point position for each class attribute after connectivity sop.
- 8531 posts
just create vector variable and assign your scalar value to first component
so on your pointcloud you do:
v@lookup = set(i@class, 0, 0);
then you can look it up using the same or other attrib:
pcopen(0 ,“lookup”,v@lookup,1,10);
or
pcopen(0 ,“lookup”, set(i@id, 0, 0) ,1,10);
or whatever you want
however if you are just doing that to get all the points containing certain attrib value then you can use findattribval() function
or
