Hi guys,
I understand this question is sort of basic. I tried to find related info on this site or internet but I can't. Is anyone can give me some hint? Thanks!
Difference between vector and 3 float
22925 16 6- kzchen
- 20 posts
- graham
- 1906 posts
On the surface they behave similar but there is a subtle difference. A vector and 3 floats both store the same information, but a vector attribute can be transformed. For example, if you create an attribute that is 3 floats and assign some values, then use a Transform SOP to rotate your geometry the values remain constant. However, if you change the type to Vector you will notice that the values are transformed as a vector as you rotate the geometry. The advantage of this is that you can have vector attributes that are properly transformed as your geometry changes so your vectors are always consistent with the modified geometry. If you just want to store a triple of values you can use 3 floats.
- old_school
- 2540 posts
I do believe a 3 float vector like P for position can be transformed but everything else Graham stated is quite correct.
Generally 3 float vector attributes are used to store position data like “P”, “uv” and “rest”. It is also used to store any arbitrary three values per point like “Color” and “scale” (used in instancing). It makes sense to translate “P”, “uv” and “rest” while you don't want to translate “Color” and “scale” where other operations are valid/common.
vector3 attributes are used to hold vector data such as “N” normals, “v” velocity and for storing the result of subtracting two 3 float vector Point positions used all the time to get direction (XYZ values) and magnitude (length of the vector).
As Graham stated, you want to transform 3 float vector data differently than vector3 data. Both take transforms differently. 3 float vector data is actually moved in space with a Transform. vector3 data is transformed along the points to keep their orientation wrt the transform rotation and scale.
One exception to transforming vector3 data is point surface Normals “N”. They require a different transform. Thankfully “N” attributes by default are transformed this way by SOPs that deform geometry.
- acaiborka
- 31 posts
Hi kzchen,
Peter Quint Houdini Tutorial on Vimeo
Basics : Attributes III
http://vimeo.com/channels/54102#6803939 [vimeo.com]
- kzchen
- 20 posts
- circusmonkey
- 2624 posts
- neil_math_comp
- 1743 posts
Let's take a step back. Suppose that you have an attribute that is 3 floats. You might or might not want the attribute to get transformed by SOPs like Transform, Transform Axis, Soft Transform, Copy, Object Merge, etc, but there are different ways that such an attribute might be transformed, depending on what it is.
Using Attribute Create, if you put the attribute name in the “Name” field, and click the second drop-down over from the “Type” label, you'll see a bunch of options. You can use this to change the transform type. The ones that are relevant for 3-float attributes are:
* None: Doesn't transform at all. This is useful for attributes that either aren't positions, vectors, or normals, or that you just don't want to transform, like “rest”. The attribute will have “3f” in the middle-mouse menu.
* Position: Responds to translations, rotations, and scales, acting as if it's a point position. The attribute will have “3fp” in the middle-mouse menu.
* Vector: Responds to rotations and scales, acting as if it's a velocity. The attribute will have “3fv” in the middle-mouse menu.
* Normal: Responds to rotations and non-uniform scales, acting as if it's a normal vector on a surface. (e.g. Normals don't change under uniform scaling, and they change “opposite” from the way vectors do under non-uniform scaling.) The attribute will have “3fn” in the middle-mouse menu.
* Color: Doesn't transform at all. This doesn't really get used for much, functionality-wise. The attribute will have “3fc” in the middle-mouse menu.
If you have a 4-float attribute that you want to transform as quaternions, you can choose Quaternion (“4fq”), and if you have a 9-float or 16-float attribute that you want to transform as a 3x3 or 4x4 matrix, you can choose Transform Matrix (“9fx” or “16fx”). I'm not sure what'll happen for other combinations.
Hopefully that helps clear things up a bit.
- SreckoM
- 379 posts
- anon_user_37409885
- 4189 posts
- neil_math_comp
- 1743 posts
MartybNzThe Attribute Create page has a little bit about it, and the Transform page says to use Attribute Create to set the transformation type, but the clarity could probably be improved. I'm not sure where a good generic page would be for it, but someone who works on the docs was asking me about this stuff just a few days ago, which is why it was fresh in my mind, so they probably have some idea.
Neil's description kicks butt over what is in the documentation.
Add some .gif animations with Scene Visualisers and it would be killer!That'd be cool. Pro tip: the “Axes” visualizer type works with quaternions, which makes it sooooo much easier to work with quaternion attributes. :wink:
- mestela
- 1737 posts
agreed! discovered that the other day when writing up some notes on rotation, its the bees knees (and when combined with animated gifs, hooooo-mama)
http://www.tokeru.com/cgwiki/index.php?title=HoudiniVex#More_on_rotation:_Orient.2C_Quaternions.2C_Matricies.2C_Offsets.2C_stuff [tokeru.com]
- circusmonkey
- 2624 posts
- neil_math_comp
- 1743 posts
@mestela: Cool!
Note that sample_sphere_uniform will sample uniformly from vectors *inside* the unit sphere, whereas sample_direction_uniform will sample uniformly from vectors on the surface of a unit sphere, i.e. unit vectors a.k.a. direction vectors. The code that figures out the transformation to do should normalize the vectors, so it should be okay either way, but sample_direction_uniform is a little faster. You can also get uniform random orientation quaternions using sample_orientation_uniform, or uniform within some angle of a base orientation using sample_orientation_cone.
- mestela
- 1737 posts
Good to know, thanks!
My beef with all those functions though is that they're too damn long to type. I hate to bring up the M word here, but Maya's ‘sphrand’ is short, easy to remember, handy. Autocomplete is good n all, but sphrand just flows across the keyboard like warm butter. Cmon, type it with me…
…sphrand……. sphrand….
-matt
-matt
- neil_math_comp
- 1743 posts
Thanks to pusat for reporting that Attribute Create wasn't letting 9-float attributes be marked as transforming as a Transform Matrix! This should be fixed in tomorrow's build of Houdini 15.5, and if anyone needs it in 15.0, let me know, 'cause it should be easy to backport the fix. (Hopefully nobody is unknowingly relying on it not working.)
- animatrix_
- 4512 posts
Thanks to Neil for slaying this bug
This is uncommon in this industry to have this kind of legendary team that stands behind their product who are very proactive in fixing any issues that show up.
Edited by animatrix_ - 2016年7月13日 16:27:27
- probiner
- 339 posts
ndickson
Hi, sorry for the necro-posting I just wanted to add to this information:
Position sub-type of Float type is sensible to what you put in the in Pivot input of a Transform SOP, while Vector sub-type doesn't care about it.
Vector type will behave the same in this regard as the homonym Float sub-type.
More over, any attribute created through Bind Export VOP or Set Attribute VOP will not be affected by a Transform SOP at all, since apparently one can't set those subtypes through those nodes!
Edited by probiner - 2017年7月19日 23:54:19
