I want to create a new geometry operator. The operator will load a set of point clouds from specified files, then decorate them with a few new attributes. At present I can achieve this with a file node connected to two attribute create nodes.
I would like for the new operator to take in a list of paths as a parameter (paths to the point cloud files). The number of paths depends on the number of available point clouds. This arbitrary length input parameter is what I am struggling with.
Is it possible to create a parameter list of filepaths that I can append an arbitrary number of files to?
New operator with filepath input list of indeterminate length
2048 4 0- mwnz
- 19 posts
- pwquint
- 53 posts
- mwnz
- 19 posts
- 8538 posts
have a look inside of FileMerge SOP it's loading variable number of files based on the settings
or if it's just for loadig use Instance SOP, or other methods mentioned in for example this thread and its links: http://forums.odforce.net/topic/26113-point-string-attribute-to-a-file_name-in-a-file-sop/?do=findComment&comment=151477 [forums.odforce.net]
- mwnz
- 19 posts
