Is it possible to edit .hip files by hand or script ? Whenever I tried it I just get a corrupt header error message.
Is this some DRM mechanism ?
edit .hip file
6742 11 0- dulo
- 383 posts
- graham
- 1904 posts
- dulo
- 383 posts
- dulo
- 383 posts
- dulo
- 383 posts
- graham
- 1904 posts
- dulo
- 383 posts
- dulo
- 383 posts
- Allegro
- 696 posts
- Allegro
- 696 posts
Allegro
Or maybe it's a Windows issue?
So from what I can tell, hexpand and hcollapse don't work with windows, and instead you use hcpio [www.sidefx.com]. Is there any other documentation than this for this utility? I seem to be able to use hcpio to extract the .hip file into folders/files however I'm not having any luck using
"[where exe is located]\hcpio.exe" -o -O .\test.hip
After I enter that in the command line, it just sits there doing nothing… if I type a file name, it lets me move onto a new line, and if I type anything else it says "Warning *.* not found - skipping. Not sure what else I should be doing to assemble the .hip file.
Edited by Allegro - 2017年10月14日 20:17:51
Stephen Tucker
VFXTD
VFXTD
- symek
- 1390 posts
- dupuy.s
- 7 posts
