Delete only column edges after skin SOP
4642
6
1
Hello guys, how i can keep only rows after skin SOP. See image attach. Cheers!
- 9372 posts
- オンライン
depending on the direction you want to keep, set Connectivity on Skin SOP to Columns or Rows
Edited by tamte - 2017年12月18日 21:17:47
CG Supervisor
Framestore, NY
Can you explain more clearly pls? Thank you!
Edited by Alex Kravtsov - 2017年12月19日 07:39:26
- 9372 posts
- オンライン
It's a parameter directly on the Skin SOP node called Connectivity
CG Supervisor
Framestore, NY
Yep, i know, but i need to bool this skin sop after…
Edited by Alex Kravtsov - 2017年12月19日 11:28:49
So i have solution for this. Just of using polywire SOP and then fuse SOP.
