Selectively active rbd instances based on proximity to other active instances
2709 5 0- Andr
- 900 posts
to cut simulation time I want to have only a small part of my rbd packed objects set to @active = 1.
This is the scenario shown in the picture: a collider sphere is scaling up from 0 to 1 in an area filled with tubes.
The red tubes start with @active = 1, once a non active tube collides, it needs to wake up and be @active=1.
After a tube doesn't move for 1" it needs to be deactivated.
I'm using a Pop wrangle to set the @active attrib during sim time, but I don't know how to get the collision data..
Edited by Andr - 2019年8月1日 12:46:37
- Andr
- 900 posts
- Andr
- 900 posts
I have a new issue now.
I need to access impacts data in a wrangle inside a SOP Solver, but if I connect ‘impacts’ node to wrangle's input1 my array operations and group setting are reset on each frame.
However it would works just fine when ‘impacts’ node is not connected to the wrangle.
I have produced an hip file
My end goal is to use the i@otherobjprimnum to group the rbd packed objects as soon as they collide.
- 8525 posts
- 8525 posts
- Andr
- 900 posts
Hey, thanks for checking the file. Now it seems to work, don't know what was that, I was sure that I was checking the geo spreadsheet while the viewport was displaying the parent dopnet with ‘not following selection’ toggle.
In case of a simple domino effect: is this the right way to permanently put to sleep an object once it reaches a stationary condition?
It seems to work, but I'm wondering if it's really efficient, because I'm noticing that when guide geometry is displayed, the red (deactivated) objects seem to flicker, like it's still computing the simulation for that object. However no flickering occurs with the real geometry.
if(i@isdead==1) { i@bullet_sleeping = 1; f@deactivation_time = 0; } else if(f@deactivation_time > .2) { i@bullet_sleeping = 1; f@deactivation_time = 0; i@isdead=1; }
