Camera in Houdini, is there an "auto vertical tilt correction"?
7038 19 3- iskan
- 18 posts
- Midphase
- 833 posts
Can you describe what it does?
>>Kays
- iskan
- 18 posts
- bonsak
- 459 posts
- iskan
- 18 posts
bonsak
On the camera parameter View tab, try adjusting Screen Window X/Y's y parm, and then adjust the cameras Y Transform to frame the view. Its basically the same but not as straight forward as the Max button
-b
t makes no sense to customize Screen Window X / Y's. Can you show where to configure “and then adjust the cameras Y Transform to frame the view”?
- bonsak
- 459 posts
- iskan
- 18 posts
- anon_user_37409885
- 4189 posts
- iskan
- 18 posts
- doctorbob
- 30 posts
if i had to guess, it looks like it's actually skewing/shearing the camera matrix in one axis. so the short answer is that no, houdini can't do that out of the box. it would be possible to do it in a mantra lens shader, i imagine. but nothing you could see in the viewport.
max is full of special archviz stuff like that, which other packages don't have equivalents for.
cheers,
chrisg
cheers,
chrisg
- julca
- 216 posts
- Midphase
- 833 posts
It's basically the CG equivalent of this technique:
https://www.canon.com.hk/en/club/article/itemDetail.do?itemId=10338 [www.canon.com.hk]
>>Kays
- 7761 posts
- julca
- 216 posts
MidphaseThank you for the detail !
Even if it's very easy to set it manually (set camera rotation X to 0 and adjust the “screen windows” Y), an automatic function would be cool.
- Gagui
- 45 posts
Yes! I agree. We need an automatic function that tilt and shift the lens to adjust to camera target. It's very important for architectural visualization and motion graphics.
I know that vray has an option to add this property to a camera via vray physical camera properties but it's visible only in the render not in the viewport so it's difficult to work that way.
- protozoan
- 1621 posts
It's available in Houdini 19 (possible even as early as 18.5), it's called "physical lens" in Solaris, and does a couple of interesting things, including tilt/shift.
In your LOPnet, put down a material library, add a physicallens VOP and reference that as the lens shader VOP from your camera (it's under the "karma" tab).
Martin Winkler
money man at Alarmstart Germany
- Gagui
- 45 posts
- brianrwalters
I tried, and no, it's still not visible in the 3d viewport. This makes it really hard to work with. I sure hope sidefx can add support.
To my simple eyes, Vertical Aperture Offset (for USD, winx/winy for an obj camera) look aboooout the same as a vertical lens shift. (I'm able to keep vertical lines vertical). Can someone calrify what's the difference between the two?
- R_Stewart
- 56 posts
Hello all, I'd say that this is a much needed feature in all 3d packages. I personally need to render things at very specific perspectives with all verticals straight so that the content fits on a big screen and still feels like the same perspective as the viewer.
See what I do here. I move the camera down to eye level, keep all rotation at zero and extend the view to get all the pixels I need. Then render a patch. Seems dodgy but it does the trick for me
I can't actually find the aperture offset that you are talking about. Can you point me in the right direction so I can try that?
Edited by R_Stewart - 2022年5月2日 20:00:52
- 7761 posts
brianrwalters
I don't see lens shaders ever being supported in a gl view, unless the gl view uses raytracing extensions. it's just not possible to control the imaging with a lens shader when rendering with rasterization.
brianrwalters
Vertical/Horizontal aperture offset is what I would use. The lens shader is overkill for a simple 2D transformation.
R_Stewart
Use the window offset to shift the image. You don't need to extend the image. Window offset is on the View tab of the camera object.
R_Stewart
Aperture offset is the USD term for window offset, and is only used in Solaris/LOPs.
