Multi-threading: Single work Item
3035
8
0
Marti_M
2019年11月8日 9:31
Hi all. I am struggling a bit with managing multithreading during the processing of the TOPs graph. I have lots of light work that should run in parallel and the two steps that are memory intensive and need to run in sequence but on all cores. Things I tried: Creating new scheduler (set it to single only and the CPU or thread count to max) - this runs but never runs multithreaded. Setting the FetchROPS to single only and the CPU or thread count to the max - this runs but never runs multithreaded. Is there some magic to manage the CPU/count on a single work item? It always seems to be single-threaded. Thank YOU!
Edited by Marti_M - 2019年11月8日 09:33:27
BrookeA
2019年11月8日 9:37
Hi, are you setting the Houdini Max Threads parameter in the Job Parms folder?
Marti_M
2019年11月8日 9:43
Yes, I am. Any suggestions?
Edited by Marti_M - 2019年11月8日 09:46:26
BrookeA
2019年11月8日 9:47
Are you able to attach your .hip file?
Marti_M
2019年11月8日 9:53
BrandonA Are you able to attach your .hip file?Indeed the scene is attached.
ISLAND.hiplc (1.8 MB)
BrookeA
2019年11月8日 10:57
Hmmm, I'm not able to reproduce the problem. I'm seeing max utilization across all of my cores when I run the ROP Fetch. A couple questions: - Which Houdini build are you on? - Which operating system are you using?
Marti_M
2019年11月8日 11:01
- Which Houdini build are you on? Latest production build. 17.5.425 -Which operating system are you using?Win 10 currently will try to nuke my preferences and see if it helps.
Edited by Marti_M - 2019年11月8日 11:02:32
Marti_M
2019年11月8日 11:08
Update resetting prefs helped.
Thank you for the help Brandon (kinda pointed me to it is me not you") direction! Now to figure out what was the culprit.
M
Edited by Marti_M - 2019年11月8日 11:11:33
BrookeA
2019年11月8日 11:15
No problem! When a job is scheduled by the local scheduler, it will set the job's HOUDINI_MAXTHREADS environment variable to the value of its Houdini Max Thread parameter. If something in your environment was overwriting that value, that may be a potential culprit. Glad that it's working now!
