Simulation whit two computer or more ?
   3126   6   2
Hello, I'm asking myself a question I have two 12 cores machines each and 32go of ram I was wondering if it was possible to do my water simulations with both machines?
Later I will have access to several workstations with houdini license to manage my renderings, I would like to know how to do it for simulations and if it is possible?
Sorry for my english but i learn too ^^
1 ryzen 3970X 64go
1 xeon hexacore 32go
1 i7 hexacore 16o
There are a number of ways to distribute a simulation, but it usually means splitting up your sims into separate parts. This suits some simulation types better than others. HQueue is often used for this.
Here is a link to a recent tutorial on setting up HQueue and using PDG.
https://vimeo.com/323269057 [vimeo.com]
David.
Edited by daviddeacon - 2019年12月2日 05:29:08
Hi David !
Thank you for your help
1 ryzen 3970X 64go
1 i7 hexacore 16o
Well, I was able to configure the server and client
when I connect to my server I can see the “home hqueue”
I see my client connected, but if I start the job from houdini I get an error message
Error
Failed to save output to file ”Traceback (most recent call last):
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/soho/python2.7/HQrender.py”, line 361, in
render()
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/soho/python2.7/HQrender.py”, line 150, in render
hqrop.submitJob(parms, _submitRenderJob)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\hqrop.py”, line 35, in submitJob
submit_function(parms)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/soho/python2.7/HQrender.py”, line 231, in _submitRenderJob
parms, hip_file)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/soho/python2.7/HQrender.py”, line 350, in _getProjectName
hqrop.getHQueueServerMachineFromURL(hq_server_url))
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\rendertracker.py”, line 48, in getConnection
_render_tracker_connection.isRunning()
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\hjsonrpc.py”, line 92, in __call__
response_code, response_data))
RPCException: Server returned error 500: b'
PIPELINE DISTRIBUTION TOOLS
VERSION {{::base.VERSION}}
Jobs
Clients
Resources
Groups
Notes
Network Folders
Help
There was a problem displaying this page.
Error: (500, Internal Server Error)
Please notify your system administrator. More information can be found in the errors.log file on the server.
1 ryzen 3970X 64go
1 i7 hexacore 16o
Maybe this thread can help https://www.sidefx.com/forum/topic/38678/?page=2 [www.sidefx.com]
I note that there is a daily build that fixes this problem (it did for me). That said it still isn't working for me due to other problems. I'm interested in knowing if anyone is actually using HQueue with H18 that doesn't use the default network mounts?
-Drew
bgood
Error
render()
parms, hip_file)
Thank you drew
1 ryzen 3970X 64go
1 i7 hexacore 16o
