instance pos wrong
   2458   3   0
I use a heightfield_scatter to scatter some instance.
Because heightfield self contain two point,
when use
if (!HEU_GeneralUtility.GetArray3Arg(_geoID, _partID, HAPI_RSTOrder.HAPI_SRT, session.GetInstanceTransformsOnPart, instanceTransforms, 0, numInstances))
HEU_PartData.cs line 776
to get instance pos, the first two instance pos is zero.
Is this a bug or i set something wrong?
Thanks.
Edited by ChenA - 2019年11月28日 05:41:16
Same problem, I took hours to identity this bug, apparently, GetInstanceTransformsOnPart returns transforms started from ALL points regardless “part” index, as a workaround I have to add a “Sort” to have instanced point attributes sorted before other heightfield layers primitives.
I tested on Houdini 17.5.173, 18.0.287, all no luck. BTW, where can I report a bug to SideFX?
imskull
https://www.sidefx.com/forum/topic/38188/ [www.sidefx.com]
Chris McSpurren
chrism
imskull
Reported, thanks.
