I want the curves to deform based on the user strokes, the only difference is I want the root and tips to lock in place with no constraint on the length. I figured I would simply use the guide groom sop and add an attribute wrangle after it to copy back the positions of the tips and wrap this up into an HDA. I figured that, like when using a stroke or a draw curve sop, to expose the viewer state, all I needed was to promote the guide groom sop parameters to my HDA and add stroke to my node default state, but it isn't working. It gives me this error as soon as I start drawing in the viewport:
Invalid source /obj/geo1/subnet1/guidegroom1/extract_ramp_data/python1
Error: Python error: Traceback (most recent call last):
File “”, line 12, in
File “D:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\hou.py”, line 13107, in attribValue
return _hou.Prim_attribValue(*args)
ValueError: invalid null reference in method ‘Prim_attribValue’, argument 2 of type ‘HOM_Attrib &’
Any idea how to fix this? Or any alternative to creating a similar custom grooming tool?
I've looked into the guide groom to figure out how it worked, but it's such a complex node. I guess I could do a duplicate of that operator into a new HDA and append an attribute wrangle directly inside that new version of the node to add the desired behavior… it just feels like a huge hack and I figure there must be an easier way to get that type of tool up and running !?
