Hello, I just found about about Houdini. I'm interested in transferring to Houdini from a Cycling74 Max patch.
The patch changes the color of material regions on a ‘dalek’ object when a voice rises above a particular level from a mic input, so that the dalek's eye flashes on and
off. The cycling74 patch also vocodes the voice input, which I show in the attached image.
In Houdini, how would I import a voice file and set it up to modulate a light?
Using sound to change light parameters for a dalek's eye?
1463 3 1- ErnestLeonardoMeyer
- 6 posts
- Midphase
- 833 posts
You would use CHOPs.
Here is a tutorial video that should give you an idea of how the whole thing works:
https://www.sidefx.com/tutorials/audio-driven-animation-1/ [www.sidefx.com]
>>Kays
- goldfarb
- 3455 posts
- 6 posts
