Crowd Agent initial offset?
2374
4
1
Dedrich
2020年10月18日 0:36
Hi guys, I'm getting into some crowd work but the assets I was given are all facing forwards in the X axis, they should be facing forward in the Z axis. Because of this no matter what I do they are running sideways. Is there anything I can do to easily fix this issue without having to go back to the client and ask them to modify their rigs?
Enivob
2020年10月18日 9:43
Can't you just rotate the sources right after Agent import?
Edited by Enivob - 2020年10月18日 09:44:17
Using Houdini Indie 20.0 Windows 11 64GB Ryzen 16 core. nVidia 3050RTX 8BG RAM.
Dedrich
2020年10月18日 11:20
If I use a transform or agent edit I can fix the way its pointing, but it seems like once it hits the crowd solver it ignores those changes.
cwhite
2020年10月19日 12:08
If the source animation is rotated, you could try setting the Reference Direction / Reference Up parameters on the crowd solver
Dedrich
2020年10月21日 18:23
cwhite If the source animation is rotated, you could try setting the Reference Direction / Reference Up parameters on the crowd solverWow….. HOW DID I NOT NOTICE THAT! Thank you so much!
