Labs Maps Baker -> Normal Transfer Problems
8681 16 2- ron281279
- 36 posts
Hey!
I use the new Maps Baker create a texture atlas for multiple meshes.
Therefore i need to transfer textures from one UV (original) to a new UV layout (with multiple objects sharing one UV space).
I am using “Nearest Surface” as tracing mode, the new UV layout as Low Poly and the original as High Poly.
This works fine.
When transfering the Normal texture though, things get messed up.
Looks like the baker takes the World Aligned Normals and adds them to the transfered normal map or something?
When I use the Normal textures as base color in the material, everything looks fine.
This used to work back in Houdini 17.5 with the old GameDev Maps Baker. Did something change?
Is this a bug?
See the attaced screenshots: one uses the albedo channel, one the normal channel when baking.
This works fine.
Is this a bug?
- Nathanielbell
- ron281279
- 36 posts
- alfyou
- 18 posts
- Ambrosiussen
- 197 posts
alfyou
FYI, I had to create a new output that only did transfers, instead of leveraging the world normals for the normals output.
The above issues should already be fixed. As for “just transfering”.. Please be careful. You can't just sample from the Tangent Normal maps and use that value. You need to transform it into the correct tangent space of the lowpoly!! (Hence the conversion to World, and then Tangent in the tool)
Paul
- alfyou
- 18 posts
Ambrosiussenalfyou
Paul
I'm not versed in this area at all. Would this only be applicable if we are doing any poly reduction?
When kept with the original workflow (conversion to world then tangent), without changing any of the geometry, we were getting artifacts and pinching for geometry such as a blanket.
- Ambrosiussen
- 197 posts
- alfyou
- 18 posts
- Ambrosiussen
- 197 posts
- alfyou
- 18 posts
Thanks Ambrosiussen,
I've tried caged mode (same as the hi-res poly input) with visualize ON, but there is no visualization that shows up.
Tests using various levels of Max Trace Distance results in a “shattered” normal map (attached). Other modes show a more normal, normal map (not attached, NDA most likely required).
Visualization DOES show up if using Surface Normal, but I can't find a value there that works without the artifacting we're seeing.
I'm using sidefxLabs build 402 and Houdini 18.0.400.
- Ambrosiussen
- 197 posts
- alfyou
- 18 posts
Ambrosiussen
These artifacts are almost 100% caused by overlapping UVs. Could you attach your file and I will take a look.
I've sent you a follow up message. Thank you for helping us take a look at this. I believe I'm not using the caged input correctly (using the same input as the mesh itself)
Edited by alfyou - 2020年3月12日 19:55:04
- ocalaf
- 21 posts
I have some problems with normals maps and UDIM's, in fact there's this other post with more information [www.sidefx.com], does anybody faced this situation?
thanks in advance!
thanks in advance!
- vinyvince
- 255 posts
Was this issue solved by Sidefx ?
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
- Ambrosiussen
- 197 posts
- kuimig
- 16 posts
安布罗修森Hello Ambrosiussen
Yes that issue should not exist with a daily build of Labs. If it does, please submit a ticket with support and I will take a look
Is there any good solution for UV overlap or UV shared material baker? The same problem will arise. I have to say that UV sharing in games often occurs
Thany you
yvjunewang
- kuimig
- 16 posts
