HDA Promote object merge path to TOP node
   1525   1   0
Hi All ! When I use an object merge node in my .hda to get some unity mesh as inputs, it works well.
But when I promote the path parameter of the object merge to my TOP network wich use differents hda it doesn't work in Unity.
It get no input.
Thanks !
Edited by Edwin88 - 2021年9月22日 05:36:16
Hi, can you give an example HDA? It might make it a lot easier to identify your problem.
