Hi.
I have a really simple TOP network. I am trying to use ImageMagick to convert to EXR while also saving out the EXR's as mipmap. Going by the online help I think I am typing the command correctly but it does not seem to mipmap. Has anyone else had any luck with this?
Best. Mark
PDG ImageMagick MipMapping
1440 4 2- Mark Wallman
- 645 posts
- pbowmar
- 7025 posts
Have you tested command line Magick at all? I usually set up everything command line (the order of things sometimes matters for conversions, for example) then translate it into PDG once I have it fully working. Then you can see what PDG is executing in the Python code it outputs, making debugging easier IMO.
Peter B
Peter B
- Mark Wallman
- 645 posts
- icecreamumai
- 59 posts
I'm guessing why you get error is that ImageMagick Binary Path is not set correctly, maybe?
(check the Custom ImageMagik...then set the ImageMagick.exe)
Here's something I set for combining nth images into one picture, using ImageMagick PDG node(in Houdini 18 though).
Maybe you might find useful. Cheers,
- Mark Wallman
- 645 posts
