- The Reference LOP seems to be creating a SubLayer and I'm guessing that its opinions are beating out the variant, is that so?
- Why is the reference LOP a SubLayer here?
- Are composition arcs the only thing that causes a LOP to create a new in-memory layer?
Reference LOP creates sublayer?
1689 8 2- traileverse
- 355 posts
In the file attached, I used the reference LOP to reference or payload in a sphere, then add a variant, however, the variant appears to do nothing even though variants are stronger than references and payloads. So, I checked the composition and
hou.f*ckatdskmaya().forever()
- 7659 posts
traileverse
don't all nodes create sublayers? The reference node would sublayer a layer with a reference. The usdrop set to flatten implicit layers removes these node layers.
- traileverse
- 355 posts
jsmacktraileverse
Yeh I'm seeing that all nodes create sublayers, I didn't understand this, but now I'm understanding why the last LOP node in the chain usually is the strongest opinion because of this sub-layering. So to confirm, that's the reason why I'm not seeing the result of the variant in this case?
- 7659 posts
- traileverse
- 355 posts
jsmacktraileverse
I'll defer to someone with more usd knowledge than I on that one. Maybe Chris R is around? @goldleaf
yeah, I really want to get a more comprehensive understanding of how LOPS treats these composition arcs
- robp_sidefx
- 447 posts
If you look at the active layer, it should look something like this:
The variant's transform isn't doing anything because you've directly specified a transform on the prim (via your transform2 node). If you move transform2 above the reference node (i.e., so it affects the sphere being referenced - vs the sphere after it's been referenced), the variant will take priority.
Hopefully this makes things more and not less confusing
The addvariant node should be giving you a warning that your variant is authoring opinions which are weaker than existing ones.
def "sphere1" (
customData = {
int[] HoudiniPrimEditorNodes = [14, 13]
prepend payload = @anon:0x7ff56b02c080:LOP:rootlayer@</sphere1>
variants = {
string model = "sphere_moved"
prepend variantSets = "model"
matrix4d xformOp:transform:transform2 = ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (-1.2, 0, 0, 1) )
uniform token[] xformOpOrder = ["xformOp:transform", "xformOp:transform:transform2"]
variantSet "model" = {
"sphere_moved" (
customData = {
int[] HoudiniPrimEditorNodes = [14, 12]
matrix4d xformOp:transform:transform1 = ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (2.6, 0, 0, 1) )
uniform token[] xformOpOrder = ["xformOp:transform", "xformOp:transform:transform1"]
- traileverse
- 355 posts
robp_sidefx
If you look at the active layer, it should look something like this:def "sphere1" (
customData = {
variants = {
"sphere_moved" (
customData = {
what about the fact that variants are stronger than references?
- robp_sidefx
- 447 posts
traileverse
The scene, as provided, doesn't contribute transformations via a reference arc. There are local opinions (transform2) and variant opinions. As-is, the local ones win.
If transform2 is moved between the sphere & reference LOP, then its opinion is being referenced, and the stronger variant one wins.
- traileverse
- 355 posts
robp_sidefxunderstood, thanks @robp_sidefxtraileverse
