overriding display option (wireframe)
   14891   20   5
I am almost ashamed to ask this but I cannot seem to find how to override display options in houdini.
Basically I want to display a few object as wireframe in the viewport.
This is , a very common task in any other 3D apps I worked with but I cannot seem to find a way to do it.
https://www.imdb.com/name/nm8408875/ [www.imdb.com]
There's probably a better way, but I usually just go inside the objects I want to be wireframe, put down a primitive sop, then go to the Face/Hull tab and set Close U to unroll.
In light of no other way I will start doing the same…but I may put a request feature for this one after all is so useful for optimizing the scene when you are focusing in one single mesh.
To whom it may help apparently I overlooked that you can effectively override display options for specific elements and selection on a scene under the display option marker tab There you can set display options for Scene Geometry, selected Scene geometry, current model geometry, etc. Is not the same but it works for my objective.
Nicolas Heluani
Hi Nic,
Where can I find that display option marker tab thing?
dansidi
Nicolas Heluani
Hi Nic,
This was so long ago I think I was refering to the marker tab on the display options of the viewport (pressing d on a viewport) the options there were of help to me.
Thank you Tony_A for your answer two years ago.
Add the detail attribute ‘gl_wireframe’ with a detail wrangle:
i@gl_wireframe = 1;
オンライン
jsmack
i@gl_wireframe = 1;
Thank you for the tip !
Please is there a parameter to always display object as textured/shaded ?
You mean to override the display mode for a specific mesh when the pane's display mode is wireframe? That you cannot do because the the wireframe mode draws the geometry differently, there would be no way to render specific elements shaded. Only in a full-draw shaded mode can some elements be forced as wireframes, (or converted geometrically to open lines.)
Edited by jsmack - 2018年12月18日 04:31:01
オンライン
Ok, it's too bad but thank you for your response.
jsmack
i@gl_wireframe = 1;
Nice!what about other display modes? where can are these attributes listed in the documentation?
They're documented in model/attributes, under Viewport display attributes. There are four:
- gl_wireframe - force wireframe (1) or shaded (-1)
- gl_lit - draw with lighting (1) or no lighting (0)
- gl_showallpoints - draw points even if connected to geometry
- vm_cuspangle - angle in degrees for generating cusped normals
twod
The first tab of the visualize sop can set some or all of these too, for more of a ‘user-friendly’ method.
オンライン
twod
That's fantastic !!!
The ability to set some shaded (and textured !!) mesh while other are wireframe are super méga usefull !
Anyone know how to do this with the new Vulkan viewport. These seem to not work anymore.
Edited by smbell - 2025年9月16日 21:32:22
What do you need that the Visualize Properties node can't do?
CYTE
Is there any way to adjust the settings of the "visualize" SOP of multiple objects simultaneously ?
You could merge a bunch of objects and change the visualize there....does this helps achieve what you want?
Nicolas Heluani
Thanks, I was afraid of that.
Wonder why only display settings like "bounding box" or "point cloud" are available at Geo level, and not all other display settings. What a huge timesaver that would be...
