Skin with smooth transition
   2240   2   0
Hi. i want to produse acurate procedural skin (sweep, bridge).
I want to get smooth trasition between two faces. Like in this image http://i.imgur.com/Z37FK9d.png [i.imgur.com]
I tried skin, sweep, bridge, loft, copy SOPs and it combinations, but the result is not acurate as I need.
All I get is good smooth curve between faces. But how to connect faces with the same topologies but with different shapes.
Any ideas?..
test scene:
https://dl.dropboxusercontent.com/u/75376916/sweep.hipnc [dl.dropboxusercontent.com]
https://gumroad.com/alexeyvanzhula [gumroad.com]
have you tried Blend Shapes?
I have an older example using blend shapes along path.
blend_path.hipnc (166.7 KB)
Thanx man! I will check it…
