UDIM uv layout ?
   8310   6   2
I have UDIM attribute 1001 but the uv layout lays it down on 1002? Basically everything is shifted by 1.. ? it seems to get 1000 as 1001. ?
what i want is:
Seems like a difference in the interpretation of the convention.
Could be that they start counting from 0 instead of 1?
You can probably just subtract 1 to get your desired result, right?
If its a matter of shifting everything around, you could use a UV transform SOP.
- I have no idea whether an established convention is being broken here and whether this should be seen as a bug because of it.
スタッフ
Doudini
Could you attach a simple .geo file?
its not about the geo, its about houdini handling the udim attribute wrong. its shifted and starts at 1000 instead of 1001.
just drop a grid add a uv texture and attribute udim with 1001,
then do a uv layout with udim and it will be put on 1002.
put 1000 in it and it will be 1001.
anyway find attached the file.
udim_1001.hipnc (51.1 KB)
This should be fixed in 15.0.369.
I am having a weird behavior and I am trying to find out if I am doing something wrong.
It seems to me that the placement is inverted in related from what I see on screen and the uv viewer I have to negate the texture scale and offset it back to make it right, did anyone experienced this behavior?
I am using H15.5.565.
Thanks in advance.
Edited by mzigaib - 2017年2月22日 12:12:01
https://vimeo.com/user2163076 [vimeo.com]
Anyone?
