Multiple objects (individually editable) on a curve
   421   1   1
I'm trying to duplicate objects (spirals) along a curve. I created two for-each cycles: 1- to move objects along curve 2- to duplicate object parameters. The first cycle is correct, but the second cycle does not work properly. I can't understand how to give the possibility to modify the individual parameters of the spirals (radius, loop, height, etc.) for each object created.
Can someone help me?
In the Edit Operator Type Properties I added a Multiparam Block (list) with: Position on curve (for first for-each) and Height (for second for-each).At the moment when I add for example two spirals only a heigh value works, modifying both spirals and not the specific one.
ExampleSpiral.hda (34.6 KB)
ExampleSpiral.hip (127.4 KB)
I found a solution.
ExampleSpiral.hip (124.4 KB)
