Using sopcreateedit to extract delta
   2738   5   0
Am having problem using sopcreateedit keep getting error
Hey seifdune,
I dont know what you are trying to do. But i had the same issue a couple of weeks ago. If you want to create corrective blendshapes you should take a look at the pose space deform workflow. It is great and works completly procedual.
Cheers
CYTE
Yap i was trying to create corrective blendshape,am trying to use pose space deform but houdini is crushing. How to wire it? I
Hey seifdune,
When your scene is crashing you should try the tool with a simpler test-setup. Create a fresh scene then make a cylinder and deform it with two bones. There is a pose space deform shelf tool. Use this and follow the instructions.
Cheers
CYTE
Ok thanks. How about mixing more than two blendshapes for facial rigging. Two work fine but when i add the 3rd blendshape the result become weird and broken.
If you add more blendshapes, make sure you have the correct amount of “Blends”. Also, click the “Update Channel Names …”, it will update your blends.
