Play with the following things: This is a combination of voxel resolution, flatten distance, and regional voxel scale. You need to find the right blend between them.
Also, I should not, it is often suggested that the border that you find there could more easily be corrected in comp. That might be your safest bet, if you can't get the parameters I suggested working well.
