Hello
I am applying random image sequences to a bunch of planes. Everything works but the random function spits out duplicates and triplicates of some textures. Is there a way to make sure it picks at least one of each of the 80 textures in the range specified by the fit function?
There are 80 folders numbered 1-80, in each folder there is an image sequence “IGS.png”:
the string value for the local override is: “ERENDERS/BATCH/`floor(fit01(rand($CLASS),1,79))`/IGS`padzero(3,$F%431)`.PNG”
The random function calls a different folder for each primitive. But as you see in the Geo Spreadsheet I get triplicates and duplicates, some folders are skipped entirely…
I solved it in a way by simply making this “ERENDERS/BATCH/`$CLASS+1`/IGS`padzero(3,$F%431)`.PNG” Then each primitive calls the folder but if the number of primitives increases and there is no corresponding folder I still want them to get assigned a texture….
Any advice is much appreciated..
Random Textures skips some and duplicates others, how to make sure one of each is picked?
1079 0 0- polimpiado
- 42 posts
