hello
On a multiparm hda to unity, I'm using path deform with several meshes. I can play with scale, curve offset etc. I need to know the start & end of each meshes in % of the curve. I want to expose as read-only to the user those start & end values.
To do that I expose two values of uv promoted on detail, during a for each loop.
So I use 2 points, read uv.y values for each and send them to detail.
Details seem to store only the last mesh values inside the loop, I can only see the last mesh
On single pass of the loop, it's good.
I do not know what to do…
Thanks for your help.
Detail attribute 'stored' on for each loop
2565 6 0- innocent
- 35 posts
- tamte
- 8525 posts
- innocent
- 35 posts
- innocent
- 35 posts
I've replaced my promote to primitive instead of detail.
As default value on my multiparm for ‘start’ I use :
prim(“/obj/geo1/subnet1/Area”,1,“start”, 0)
& for ‘end’, because primnum is never the same, so I cant give a direct number of primitive
prim(“/obj/geo1/subnet1/Area”,`nprims(“0”)-2`,“end”, 0)
but it stuck to 0, I've made a simple print and value `nprims(“0”)-2` is correct. This value change from a previous loop that refines my meshes.
I cant use `nprims(“0”)-2` on this kind of expression?
- blackpixel
- 182 posts
- innocent
- 35 posts
seems prim(“/obj/geo1/subnet1/Area”,`nprims(“0”)-2`,“end”, 0) is not updated.
If nprims change, it's not updated on the multiparm target hda
using those gives the same result 0, but on output console it's fine
prim(“/obj/geo1/subnet1/Area”,nprimitives(0)-2,“end”, 0)
or
or
Edited by innocent - 2020年6月19日 03:43:00
- innocent
- 35 posts
I'm sorry to bother you with my problems but I feel lost.
here are my steps
capture points : group create -> 2 `npoints(0)-2`
create uv :
aw ->
int maxpoint = 3;
if (@ptnum < maxpoint || @ptnum > (@numpt-1) - maxpoint)
@start = @uv.y *100;
promote point to prim
capture my values:
aw ->
float mystart = prim(“op:../promoteStart”, “start”, 0);
float myend = prim(“op:../promoteStart”, “start”, nprimitives(0)-2);
I've attached my scene
my values are good and react on the console, but only for the current mesh.
I use the same prim function on ‘default value’ on a float on my multiparm on hda, but same as previously: result 0 :/
here are my steps
create uv :
aw ->
int maxpoint = 3;
capture my values:
aw ->
Edited by innocent - 2020年6月19日 10:51:33
