So one thing I find intensely annoying in H18 is the lack of expression capabilities in the new Group SOP. What, for example, is the new syntax for the following expression from the old Group SOP?
($BBZ < 1.0) && ($BBZ > 0.95)
I'd like to make a group out of all the points whose Z bounding box coordinate is less than 1.0 but greater than 0.95. Even assuming I go to the (tedious) trouble to create an attribute called, say, BB to store the bounding box values (because the new Group SOP does not allow referencing locals anymore), I still can't seem to put compound conditionals in the Base Group parm like this:
@BB.z<1.0&&@BB.z>0.95
Not only is this horribly unreadable thanks to the inability to use spaces in the new expression syntax, it doesn't even work.
Alternatively, is there a way to drop down the old Group SOP in H18?
Equivalent of old Group SOP expressions?
1535 6 1- jrcooper
- 59 posts
- N-G
- 209 posts
- jrcooper
- 59 posts
Thank you for that example. It was very helpful.
I have to say, though, that this VEX-based approach to things is incredibly obtuse and inconvenient compared to the older methods that the old Point and Group SOPs used to provide. This is especially true for setups that aren't overly complex or slow to cook. Many times, clarity of intent–which a simple expression like “($BBZ < .95) && ($BBZ > 1.0)” expresses very clearly and succinctly–is preferred over an esoteric collection of multi-parms like in the Group by Expression SOP which happens to execute faster.
- N-G
- 209 posts
- jrcooper
- 59 posts
- jsmack
- 7733 posts
- bunker__
- 21 posts
