i have a very simple cop2net that processes an input image and i have turned this small setup into an HDA with some parameters exposed.
i want to run the HDA for every image from my pc directory, have the HDA parameters wedged and export each time the generated image.
i am new to pdg and it all seems quite complicated.
1) Using the file pattern i import my images - there is a parameter in my HDA that needs the path for the currently processed image - how do i do that? @pdg_output didn't work.
2) How do i export the cop result to disk?
3) how can i name my resulting images using their original name (how do i access that filename?) plus their wedge numbers
