Load the python file saved using hou.Node.asCode()
   2794   1   0
Hi Folks!
I'm trying to serialize and save nodes to disk using the hou.Node.asCode()
When I save a node to disk using asCode() like this:
node_to_disk.asCode(False, True)
I can load the saved file from a shelf tool using the code:
execfile(file_path)
But if I want to wrap that code in a function, using
node_to_disk.asCode(False, True, function_name="func_name")
It saves the python file as expected.
But how do I load this file in houdini again?? If I try to call that function, I get an error saying hou is not defined.
Also, if I have multiple functions in that file, can I just call one at a time?
Any help will be appreciated.
Bump...
Did you ever come up with an answer for this?
Thanks,
Nick
