My caching is limited - why?
How can i change it?
first cache is recorded from start and everything is good but late blue strip is "teared" an go right
I tryed to reproduce pop network effect = VFX
381 2 1- Staglaitor
- 43 posts
- sepu
- 442 posts
- Staglaitor
- 43 posts
sepu
Depending on what solver are you using if you are using the SOP solvers then Vellum has its caching memory in the advanced tab, pyro on the setup tan under simulation, same with bullet solver, etc if you are using a DOP network under the cache tab you can change the settings.
I have set cheche size = 999999999999 and nothing. Look at these 999999999 on video
Edited by Staglaitor - May 23, 2024 09:13:31
