iasm6419
June 25, 2025 12:29:42
Instead of using the frame number ($F) for simulation in a Solver node, is it possible to drive it using a custom parameter? I'm having an issue with the Solver node while building an HDA.
raincole
June 25, 2025 22:46:25
Where is this custom parameter coming from?
I think a much easier solution is just to solve frame by frame then use Retime or Timeshift to align your solved result with this custom parameter.
iasm6419
June 26, 2025 03:25:09
Yes, I found the Timeshift node. Thank you for your help!
