Search - User list
Full Version: Pyrosolver sparse in DOPnet
Root » Technical Discussion » Pyrosolver sparse in DOPnet
Moritz1801
Hey guys i having an issue with the pyrosolver sparse inside a dopnet.
I have an animated geo that i want to emit fire from. That works perfectly with the normal pyrosolver in the dopnet and I'm happy with the result. However the animated geo that is my pyrosource travels outside of the bounding box after 50 frames and the fire disappears. Animating the bounding box didnt work and i would have to make it huge to fit the entire animation so these options dont work for me. I have been told the pyrosolver sparse would fix this problem as it automatically calculates the bounding box and only solves the areas it has to. I tried building the sim the same way as with the normal pyro solver just with the sparse solver and smokeobject sparse. My input has fuel, temperature and density attributes, that worked perfectly with the other solver. No matter what i try with the sparse solver, it only places a tiny bounding box at the world origin and nothing happens. Do I have to use the sparse pyro solver fundamentally different or is it just one tiny checkbock that i didnt notice. The setup was so easy with the normal solver, isnt the sparse solver basically the same? I'm kinda out of ideas
FedorK_FX
Sparse doesn't use fuel field for combustion.
Make sure you tick the "Enlarge Fields to Contain Sources" on the Volume Source DOP.
In general I'd recommend checking the presets like "Pyro Configure Billowy Smoke" that use Pyro Solver SOP, in most cases Pyro Solver SOP based setups reduce the opportunity for errors.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Powered by DjangoBB
