Hamilton Meathouse
Sept. 28, 2021 00:42:52
Is this by design? Gets quite annoying when you have a heavy scene with many nodes and assets to cook.
mtucker
Sept. 28, 2021 16:42:10
I'm not seeing this behavior. It might depend on what nodes you have in your scene? Is there a hip file you can post that shows the problem?
Hamilton Meathouse
Sept. 28, 2021 18:16:18
Not a production file that I can share at the moment, but i'll see if I can make a repro this week
robp_sidefx
Oct. 6, 2021 09:46:37
Just to check a few things:
* which Houdini version?
* are you changing the filename (i.e., Save As) or overwriting an existing hip?
* does it only happen the first time, or every time?
Hamilton Meathouse
Oct. 6, 2021 19:50:22
-18.5.596
-Usually Save-As, yes (incrementing version)
-Seems intermittent
Tim Crowson
Oct. 7, 2021 00:08:57
I have had this happen as well. Usually with initial saves.
robp_sidefx
Oct. 8, 2021 11:54:33
Okay, I think I know why this is happening (the Render Gallery database path is tied to $HIPNAME so if you're doing Save As then $HIPNAME changes, and the LOP Network gets dirtied). If I'm right, it's something we've already fixed for the next release, but I'll try to get it backported to 18.5. I'll post again when that's done (or if there are issues).
robp_sidefx
Oct. 10, 2021 09:33:58
Should be fixed in 18.5.727 ... let me know if you still see it happening!
Hamilton Meathouse
Oct. 10, 2021 15:05:59
Thanks Rob! I'll see if I can get pipeline to put a build together. Will report back!
Tim Crowson
Oct. 11, 2021 19:16:05
Thanks for this, Rob!
