I suspect it may be my lack of understanding of the USD..
I have a situation like on the screenshot. I am trying to "animate" the parameters to turn the light on / off using a Switch with a simple expression.
When I render inside Solaris (HYDRA_RENDER_CHECK node in my example) the light turns on and off like I wanted. After saving to USD, this modification is not saved and it looks as if only the state of the first frame was saved in USD (despite Frame Range set to all frames).
