I'm not able to correctly transform any objects in my scene any more. Houdini doesn't' update the handle position correctly and if I undo any transformations just the transform handle is moved. In some cases I'm not able to move an object in any way – even changing the parameters directly seems to have no effect. I started this project with Houdini 10 and now trying to finish it on an other machine with 11 and didn't had any problems till now.
thanks in advance
incorrect object transformation
2004 3 1- Houdinik
- 27 posts
- edward
- 7760 posts
- eitht
- 257 posts
- Houdinik
- 27 posts
Thanks edward - worked fine
@ eitht , well unfortunately not – I just switched to an other (tiny bit more powerful) laptop for rendering ^^
But HP is now working on this issue(s), they already were able to reproduce the problem (even with a certified ATI card ! ) so I hope they come up with a solution. Apart from this I still didn't hear anything useful from ATI yet , and the VBIOS update they did seems to cause even more problems with Houdini than with the old one – meaning that after six (!) month of regularly contacting the ATI support things have finally even come worse.
