Hello all!
I've noticed that in Houdini 13, within the directlighting VOP node, the outer code reads:
import directlighting;
Rather than the old way of specifying the whole function.
This is good.
But how do I import functions? Whenever I place “import directlighting;” in the outer code of any of my nodes, I get the following error:
Failed to import function ‘directlighting’. (30,1:21)
In addition, I get an identical error when trying to import it within a header. Importing it in a header is what I actually want to do: my main aim is to call directlighting() from within a header.
What do I need to do to get imports working?
The New "import" keyword in H13
5913 11 1- abvariant
- 13 posts
- wolfwood
- 4262 posts
- abvariant
- 13 posts
Hi there Wolfwood,
Well I have a VOP node that I've made, that I use within a material builder in the SHOP. I've created it as a vex builder operator. Purely as a test, I'm trying to import it within that. I suppose that would work? Directlighting is a surface shader itself isn't it.
Are you also implying that as a header itself doesn't have any context per se, I won't be able to import anything into it? I am ultimately using the header in a shading context…
- wolfwood
- 4262 posts
Hmm. Seems like it should work. Can you post a simple hip file?
The issue I was referring to is if you had wired it into a displacement shader, you'd get an error like this-
Warning: Errors or warnings encountered during VEX compile:
/shop/vopmaterial1: Failed to import function ‘directlighting’ for context ‘displace’. Only available in the ‘surface’ context. (21,1:21).
- abvariant
- 13 posts
- abvariant
- 13 posts
So when building a test scene from scratch, the error about the “import” keyword never appears but it seems to think the directlighting() call is undefined, despite the fact that I have imported it:
opshop/vopmaterial1:32:5-18: Error 1066: Call to undefined function directlighting(string; bsdf; string; void; string; void; string; void; string; int; string; float; string; string; string; int; string; int; string; int; string; string; string; int; string; vector; string; vector; string; vector; string; float; string; int; string; vector). Candidates are: void directlighting(; … )
opshop/vopmaterial1:34:13-18: Error 1031: Invalid implicit cast from vector to void.
opshop/vopmaterial1:35:12-17: Error 1031: Invalid implicit cast from vector to void.
opshop/vopmaterial1:36:12-17: Error 1031: Invalid implicit cast from vector to void.
opshop/vopmaterial1:51:21-26: Warning 2018: Using uninitialized variable: direct
mantra: Could not find VEX shader ‘opshop/vopmaterial1’ (either .vfl or .vex)
Despite this, I've attached the file I used. The otl i created should be embedded. I've duplicated the directlighting node.
This time round it's like the “import” line is just being ignored…
- wolfwood
- 4262 posts
Well well.
The code generated by the built-in VOP results in-
// Code produced by: directlighting1
directlighting(
“inF”, f,
“inOf”, { 1, 1, 1 },
“inP”, vector(),
“inI”, vector(),
vs the same asset that has been copied to a different type name.
// Code produced by: importTest1
directlighting(
“inF”, f,
“inOf”, vector(),
“inP”, vector(),
“inI”, vector(),
Notice the inOf.
What I don't get is if the asset was copied directly why it would behave differently.
directlighting(
“inF”, f,
“inP”, vector(),
“inI”, vector(),
directlighting(
“inF”, f,
“inOf”, vector(),
“inP”, vector(),
“inI”, vector(),
Notice the inOf.
- abvariant
- 13 posts
Ah interesting.
So the importTest node was actually create from scratch manually. I duplicated the code, params and node details from the directlighting node. So the importTest isn't a direct copt of directlighting.
Seems I missed off that default value for inOf. ops:
Still, it doesn't seem to be complaining about it. Just that the function doesn't exist.
- wolfwood
- 4262 posts
- abvariant
- 13 posts
- wolfwood
- 4262 posts
abvariant
Thanks, I'll try a more recent version and see where that gets me.
Just to verify, did this actually work for you or not?
Taking you scene, once I fixed the importTest VOP, so that it had a hidden Of parameter defaulted to 1, like the directlighting VOP, it then worked. No compiler errors and rendered a white sphere.
- abvariant
- 13 posts
