I experience a marked difference between booting up h14 ( very slow ) and H13 . The H14 help also takes a very long time to appear from a blank page to tyhe help index. I am just wondering if anyone else gets this experience with Houdini 14 and OSX .
Rob
H14 boot up time on osx
2689 8 0- circusmonkey
- 2624 posts
- pavelPeh
- 30 posts
The boot time is ok for me - at least I didn't noticed anything unusual.
I can confirm that the web browser is still a little bit slower when loading a page, but MUCH better than it was before (production build for example).
On the other hand my system freezes for a couple of seconds after houdini quits.
OSX 10.10.2
OSX 10.10.2
- SreckoM
- 379 posts
- mtucker
- 4458 posts
I have also seen some brief lockups when shutting down Houdini on my MBP, but I think it has to do with the laptop switching from the nVidia graphics card to the Intel HD graphics. There's a utility called gfxCardStatus that lets you lock into one graphics card or the other which would let you see if this is the problem you're seeing (lock it into Discrete Graphics mode and see if the lockups go away). If it is the video card switching there's not much we can do about it…
Mark
Mark
- circusmonkey
- 2624 posts
- Cyzor
- 181 posts
- pavelPeh
- 30 posts
- mtucker
- 4458 posts
circusmonkey
Hi Mark , its not the video card effecting the boot time or the help taking forever even with OSX 10.10.2 its slow enough I can walk away and make a cup of tea. No other applications are running.
No, I was not suggesting the video card as the culprit for the startup time, just the shutdown time. I have never seen this length of delay on startup, and I'm always running un-optimized builds…
If you wouldn't mind, could you start up Houdini, and while it is starting up do a “Sample Process” from the Activity Monitor? It sounds like you might even have time to do several Sample->Save->Refresh->Save->Refresh->Save cycles before Houdini actually comes up… That should give us a pretty good idea of how Houdini is spending its time during this startup time.
You can just post the results here, or submit with a bug.
Mark
- mtucker
- 4458 posts
pavelPeh
Thanks for the tip.I switched to nVidia only and the slowdown after shutdown is gone.
Probably there is nothing you can do aboit it. Not a big deal.
Cool, thanks for the confirmation. And no, I don't think we can do anything about it. Well, we can point our finger at Apple, but that's about it
Mark
