How to use the hou.ui.copyTextToClipboard() ?
The following error occurred:
Qt Error: OleSetClipboard: Failed to set mime data (NULL) on clipboard: COM error 0xffffffff800401f0 CO_E_NOTINITIALIZED (Unknown error 0x0ffffffff800401f0) ()
Qt Error: OleSetClipboard: Failed to set mime data (text/plain) on clipboard: COM error 0xffffffff800401f0 CO_E_NOTINITIALIZED (Unknown error 0x0ffffffff800401f0) ()
2875 2 0- newPeak
- 83 posts
- mtucker
- 4445 posts
From the error message I would assume that function uses relies on a per-thread initialization function being called before it can be used. When you run python code from a python shell, it doesn't run on the main thread. It runs on a separate thread where the per-thread initialization function has not been called. If you run the same code on the main thread (as part of a shelf tool for example), where the initialization function has been called, it should work.
- newPeak
- 83 posts
