I've searched both here and odforce.net but I dont find a good solution to this.
But when I am applying a PolyReduce SOP to my already UV-mapped object I get these horrible seams. Using Attrib transfer doesn't fix this problem either.
Any ideas ? I've supplied the .hipnc but you need to apply a texture on the Material's diffuse channel to actually see the seams in the 3D viewport.
PolyReduce SOP and UV's
11449 7 2- MagnusL3D
- 1104 posts
- Simon
- 2199 posts
Try this…
1. Add a vertexsplit sop and set it to uv, then turn on “Promote to Point Attribute”
2. Add a remesh sop and play with the values to get the mesh detail you want.
UV's should be maintained in this process without any seems. You might find they get a bit “wobbly” if you reduce the mesh too far.
The results will depend a lot on the type of geometry you are reducing and the type of map and existing uv's on it already.
- MagnusL3D
- 1104 posts
- Simon
- 2199 posts
- MagnusL3D
- 1104 posts
- Simon
- 2199 posts
As long as you use the vertexsplit sop first as directed above…
Of course this assumes you have vertex uv's in the first place, not point uvs. Though I would assume if you have seams then they would have to be vertex uv's to start with.
You can promote back to vertex uv's after the polyreduce and re-fuse the points if you need to.
- MarcoMeeuwse
- 5 posts
- 7849 posts
