![](/static/djangobb_forum/img/smilies/lol.png)
First off, here's the error message during the install:
Checking for running server… It has to be stopped before
we can install the new version
warning: saving copies of sesi* tools and licenses in BACKUP_SESI.20061004100410
tar: Pattern matching characters used in file names. Please,
tar: use –wildcards to enable pattern matching, or –no-wildcards to
tar: suppress this warning.
tar: houdini/sbin/sesi*: Not found in archive
tar: Error exit delayed from previous errors
cp: cannot stat `houdini/sbin/sesi*': No such file or directory
A problem has occurred installing the license tools.
Please correct any errors above and try again.
Houdini 8.1 Installation completed.
Please read /opt/hfs8.1.744/Readme.txt
for instructions on how to run Houdini.
*** NOTE ***
Some install errors seem to have occurred.
Your installation may not be complete.
Please correct any serious problems and re-install if necessary.
I first tried some of the various fixes I googled for houdini+gentoo, but i quickly realized that sesinetd never got copied to /etc/init.d/, nor did sesictrl go to /usr/lib/sesi/. I'm not sure what else didn't make it to where it's supposed to go. :?
I have tried copying those files to their intended destinations and then going by some of the tips posted here (for example Ben Simon's) but still no luck. I've also started sesinetd and hserver by hand, however hkey refuses to serve licences.
Any tips on how to fix her up would be greatly appreciated.
